Please Help 3gang 2 way switch | on ElectriciansForums
Discuss Please Help 3gang 2 way switch in the The Welcome Forum area at ElectriciansForums.net
Pembrokeshire
Hi I have wired up the light switch following the instructions in the picture below my upstairs light and outside light are both working fine however my downstairs light is on but I can't turn it off anyone know what I need to do to fix it
switch off and call your nearest spark .
Hi mate. Are you saying that the upstairs light, outside light and downstairs light only switch on/off from this 3 way switch and no other switches in the house?
Hi - this could be a number of things and with no test gear it's tough to sort. I have recently had one of these exact switches Dead on Arrival, so you've that possibility too.
Reply to Please Help 3gang 2 way switch in the The Welcome Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
