please help lighting problem | Page 2 | on ElectriciansForums
Discuss please help lighting problem in the UK Electrical Forum area at ElectriciansForums.net
demkap
Hi there,
im wondering if anyone can help me. im a qualified electrican but have never come across this problem. basically in a church there 6 flood lights inside on each wall left and right side. the whole right side is not working as it should. one light comes but then the next light seems to come on but not at full brightness, like theres a voltage problem. then when i flick the switch one light goes off and the other comes on but they should be on together. theres 3 switches 2 lights per switch, but its like the whole configuration doesnt work and they dont all come on or stay on....
please help???
What sort of a 'voltage problem' do you think it is, and why are you so convinced that it's that?
Personally I'd isolate the power, disconnect the fittings (you know they work) and bell everything out.
Reply to please help lighting problem in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Can you get a supply to your new light at all from elsewhere ?
