Please help with this circuit! Its not working and I have no idea why! | on ElectriciansForums
Discuss Please help with this circuit! Its not working and I have no idea why! in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. So the other day I came on here and asked for some advice on controlling the speed of a motor with a motor speed regulator. Thanks to all those who helped out.
It has now arrived but I am not sure how to connect it up. Can you help?
Here is a diagram of the circuit and the motor. I have written on the 4 connectors what they are.
[ElectriciansForums.net] Please help with this circuit! Its not working and I have no idea why! [ElectriciansForums.net] Please help with this circuit! Its not working and I have no idea why!
So I plugged the cable running from the switch in to the + Power connector, and the cable from the motor in to the - Motor connector. The connection is complete but the control knob doesnt work. What am i missing? Have I done it right?
What happens to the - Power and + Motor connectors? Are they needed? Does something need to go in them so I can use control knob. What about the red cable in my diagram? Does that need to go back through the motor speed regulator?
Many thanks.
Tim :)
Just tried it and the speed regulator blew up. It just banged and something flew off it. Well thats progress. Now I am completely baffled. I dont understand any of this. I need to know which cables go in to which part. Well it doesnt really matter any more. Nevermind.
As above - your power in on the left positive and negative
your motor connections on the right positive and negative
you pot' is connected as shown above red +, black - and white (wiper) is in the v
I assume you checked the pot' connections with a multimeter before connecting as they can vary with brand but usually the outer ones on that style will be control supply and centre the wiper... if this pot differs or you connect wrong you can short out the control supply.
Did the pot' come with the kit?
If your sure this is definately a 12v dc kit and the connections made are as we discussed then welcome to the world of cheap chinese tat... designed to make the western world feel dumb when it won't work!
It all looks very straight forward as others have said. 12v positive & negative input to controller and 12v positive & negative out to motor. Did you wire this up like your drawing suggests? as this is not right and may have already damaged the controller. Your drawing shows a direct connection from the battery to the motor completely by passing the controller.
It would have helped if you had kept this post and the other together as they are the same topic. http://www.electriciansforums.co.uk...some-help-circuit-connection.html#post1142927
I suspect you have the polarity wrong the battery -ve and +ve(after the switch) should have gone to the power side of your board the output on the board (motor) should have been conected to the motor.
The polarity is very important when using semiconductors
please ignore the wire colours shown you need to check which colour is +ve and -ve at the battery and then use diagram
Just above the IN terminal block, I see a diode (commonly called an "idiot diode"), whose sole purpose in life was to conduct if the input had reversed polarity, and blow a fuse, the tracks to it, or even itself up or go short-circuit. It would do no further harm to physically cut it out and try the module again (connected correctly, of course) before writing it off completely.
Reply to Please help with this circuit! Its not working and I have no idea why! in the UK Electrical Forum area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
I would agree that the motor is by far the best part to replace. if it is powered and not turning then it is broken. Keep it simple!
Here is my first design, I realised I can print onto clear acetate, so black areas will allow less light to come through and the lined areas will...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
4K
I have included more information on what happened after the motor stopped, and everything slowed down. The first thing I noticed was that the...
