please help with this question | on ElectriciansForums
Discuss please help with this question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
North
hi guys,
i need some help with an assignment and id appreciate it so so much if anyone can help me.
A circut which is supplied from DB 3 is protected by a 16A type C circut breaker and has a measured earth fault loop impednace of 1.35 ohms. Please determine (with reasons were applicable)
a. if this value of earth fault loop impendance is acceptable
b. at least one method of achieving disconnection should the device provide unacceptable in (a.) above with out re-wiring the circut.
c. at least one method of confirming the integrity of the live conductors of that circut under short circut conditions.
thanks alot guys for any help
oh thanks,
that simplifis things for me! thats the thing with my material im working with it just throughs something like db3 in and expects a newbie to know what that is! another thats simple to you guys but not for someone who has came across it for first time. At least now il know! lol
thanks for the help
Upvote 0
Whats the point in us just answering all the questions for you. You need books to read and get an understanding of electricity, how it works and whats being asked, then open up the regs and look for the answer.
You wont learn much doing it this way. What is this a assignment for? collage? is it an apprenticeship or quick course?...
Upvote 0
You really should stop going out on the razz - day before college.... DB 3 (not BD) is probably a ref' to Distribution Board 3 in some notes or diagram you have..... this is basic shorthand terms and should be well locked into your grey matter long before your even tasked with this level of question.... lets just hope its just a one off oversite or your gonna struggle alot and we are not into doing your homework but will guide you to the area to look as others have.
Upvote 0
You need to determine the maximum value of earth fault loop impedance that will trip the 16A breaker in the required disconnection time. This information is all in the regs book and should be what you are learning, you need to work it out for yourself
Upvote 0
No, not really. The current you are looking for is the one which makes sure the breaker trips in 0.4s, hint its much much higher than 16A, i.e. the rating of the breakers and if you think about it, it would be a pretty annoying breaker if it did trip in 0.4S at 16A.
Also there is a rule of thumb used here cos its hard to measure when its all running at max temp and current so you measure at ambient, often with low or no load.
Upvote 0
Reply to please help with this question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Electrical Courses
