Please put my mind at rest | Page 3 | on ElectriciansForums
Discuss Please put my mind at rest in the UK Electrical Forum area at ElectriciansForums.net
H
Hottub
hi guys I have had an electrician come and put some wiring in ready for a hot tub delivery.
I passed on a electrical document sent to me by the hot tub company which had 6mm on it.
He has run a armoured 2.5mm 3 core cable from the main board and a dedicated 32amp mcb to an external rotary switch ( about 3 metres away ) also 32amp. From the switch he has run the same 2.5m 3 core around to where the hot tub will be ready to be connected ( no more than 4m away ).
He says its more than enough but as I've seen 6mm on the wiring diagram I'm worried.
So shall I stop worrying? Or demand he use 6mm? Or find a different sparky?
Thank you for your time.
Worked on quite a few tubs where the recommended supply was 6mm² and 32A the reality being with the heater and all pumps running they rarely run above 18 - 20A although the inrush starting the pumps does give a short current spike
Reply to Please put my mind at rest in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
