C
ctomlinson109
I've been lookinng online to little avail trying to find a seal for a 2 gang plug socket.
We have a cat, who at the moment is spraying, and she keeps doing it above one of the plug sockets. Which then runs down the wall and often shorts the socket.
I've had to replace the socket a few times now and the cat really isn't getting the idea that it shouldn't being doing it.
But anyway, while I try to get the cat to behave, I wanted to know if there is some sort of rubber seal you can put around a socket. The socket is on a tiled wall right on a grout line, so just tightening the screws still leaves a gap where the grout is.
So is there such a thing? I don't know if I'm just using the worng wording or if it just doesn't exist outside of actual outside plug sockets.
Thanks!
Calum
Thanks!
Calum
