plumbers vs sparks rates
Should this not be in pub. Not sure it's a good idea on a public forum. Joe public thinks bad enough of us as is
Hi all, my rates depend on the type of job but when you look at some hourly rates for getting your car looked at, even the plumber is cheap.
never see a problem with stating hourly rates , as im £35 theres alot of sky high prices around
seen £75 ph recently and i could not justify this one bit
Plumber are trained to spout s**t and charge for it.
You lot just take all the s**t you're fed by you're lords and masters, and they charge you for the pleasure.
I met data cable installers that were on about £75 an hour, they don't even pull cables in, just punch down the terminals of the cables I so kindly pulled in. Why worry about who charges what? There'll always be someone earning more than you for what seems like a lesser job. Sure I could earn more working in an office? But then I wouldn't get to roll around in fibreglass and make things light up!
glasgospark,
trev,
