Plumbing in a dishwasher and washing machine. | Page 2 | on ElectriciansForums
Discuss Plumbing in a dishwasher and washing machine. in the Electrical Appliances & Whitegoods Forum area at ElectriciansForums.net
Thanks for your help I will do that but I can’t understand the difference between this dual pattrass and double socket
t5he one you will be used to is for a double socket. the one he's referring to is slightly wider with a divider and inboard lugs so as to accept 2 single sockets side by side. reason for using 2 singles is that a single socket is rated 20A whweas a double is 20A total for both sides.
see pic.
[ElectriciansForums.net] Plumbing in a dishwasher and washing machine.
see pic.
Thanks I am using white plastic surface back box is this ok
I think just a spur there is a fuse for it on wall opposite on a panel
If it’s coming off a 13A fused switch spur then you are way over the 13A limit.
your two appliances 3.8 Kw about 16 amps running through a 13 A fuse.
back to the drawing board.
you don’t design circuits where the limiting factor relied on is the person using the appliances One at a time.
If that was the case we could wire a whole house on a 2.5 mm radial. And leave it up to the consumer to choose and calculate what can and cannot be on at the same time.
not just bad practice, but bad design.
Reply to Plumbing in a dishwasher and washing machine. in the Electrical Appliances & Whitegoods Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
J
Utility Room waste Afternoon. Moving home and have a utility with a small wash basin at the right hand side, so I'm adding in a washing machine...
JonesJ89
J
H
Integrated dishwasher Hello, I’ve just bought my first home so am learning along the way! I’d like to get a slimeline integrated dishwasher...
HowesyR
H
