K
Knobhead
I know some countries use protection to guard against a broken neutral in PME systems.
Anyone know how they work?
Discuss PME & Broken neutral in the UK Electrical Forum area at ElectriciansForums.net
Doesn't the white wire on the RCD help with this?
It happened to my house years back.
I am thinking if 10 houses are on the same phase as me and the N drops off will I get all their fault load as well because my nice shiny new earth rod will provide a lower path of resistance than all their bonded extraneous water and gas ?
And if you have plastic gas/water coming in it gets worse.
J
i cant see how it would be a problem if all of the neutrakl curent was trying to go down one electrodwe. the laws of a certain mr ohm would take care of that. Aint you supposed to size the cable to the rod by best case resistance anyway? So in tother words, itys very unlikely that you would have a sub 10 ohms electrode. so the current that would flow would be 2.3 ohms. a 10mm cable for example would take that indefinately.
thy problem comeswhen people have undersized the cable to the rod, and you get a low current, long duration fault.
Reply to PME & Broken neutral in the UK Electrical Forum area at ElectriciansForums.net
