It's proposed in the 18th edition that any new pme installation is to have a rod added by the electrician that has has a resistance of 30ohms or less. What are people's thoughts on this? My main concern is the amount of services that are going to get hit with everyone driving rods in.....also my lowest reading on a rod ever was 40 ohms which I thought was good.
My feeling is it wont happen. There are simply too many buildings where the installation of an electrode is not practical due to location and the risk of hitting unknown services. In my area recently a 2 mtr coupled rod got 186 ohms, achieving 30 ohms would have been a mission on that bit of ground.
Doesn't it also say something along the lines of for new buildings earthing of the foundations should strongly be considered...so a connection to the rebar/metal grid before the concrete goes in. Could be one way of achieving a low RA I suppose. I think if it stays in the Book when published it will be written as strongly advise/consider....Then they will try and enforce it in later editions of the 18th.
I wouldnt at all be surprised if come the 2nd release of the 18th edition we will stop a lot of this European conformity stuff as by then we will be out of the EU, I agree with @Leesparkykent though that this is going to have exceptions and considerations galore that will mean its not enforceable as it stands too many ifs and buts... but given 7671 is not legally binding and advisory could we not do individual risk assessments? I do not see how the industry are going to convince homeowners that they need a rod before you can sign the certificates off when doing a job... If it gets to that stage i am buying rods in bulk and setting up shop as a wholesaler... .
Down side is that you will get your local transient community and junkies pulling them up for scrap value when not put in well.
If it ends up that a new PME must have a 30 Ohm or better rod, I'm guessing many places won't be able to achieve it and would have to refuse DNO earth and fall back to TT ? (where your average 100 Ohm rod is perfectly ok) Doesn't really seem like a forward step to me ... Or have I misunderstood?
As the draft has been closed, I can't verify, but I do recall the proposal of adding earth rod to supplement any earthing supplied by a DNO (542.1.201). And I think it related only to PME supplies, but I might be wrong there. There is also a proposal for foundation earthing in new builds (542.2.2).
Or did I just wake up in a cold sweat from a nightmare :eek:
Edit; those reg numbers are from some notes I made when reading the draft, so don't quote me on them!
No it’s applicable or maybe in this case , to any TN system were the supplier has provided an earth.
Manchester
Pme installations in 18th edition with additional rod.
David Rann,
Andy78,
