PNB again | on ElectriciansForums
Discuss PNB again in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
devlin maguire
Hi again
After further enquiry to the DNO they say they will not provide an earth for a PNB system because its going into a metal framed building and I cannot get a definative answer from them, so do I connect to the neutral terminal then to a rod, or do I just go direct to earth rod as in a TT system bypassing the earth neutral terminal at the cut out completly I have had a look at this system on line and the diagram shows no earth connection at the local transformer only at the installation end but I am asuming this is for a normal installation and not a metal building
Mac:confused:
Reply to PNB again in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
