polarity argument at work | Page 6 | on ElectriciansForums
Discuss polarity argument at work in the UK Electrical Forum area at ElectriciansForums.net
O
Olliew
What do use in emergency lighting brown permanent live black switch live or black permanent live brown switch live obviously grey neutral major arguments at work please help to settle
last time i worked on site, this clever t*** decided it would be a good idea to cut into the insulation on my VDE cutters. he wasn't happy to find a dog turd in his toolbox.
Telectrix- think I can smell something bull**** right there. Nothing to do with the argument!
I thought the argument was finished, many opinions , main consensus was that keep consistent throughout or match manufacturers lighting systems, and regards you, I think it don’t mater, you still going to "rape" your pure lads on site
:6:, feel sorry for them. lol......
I think you are a very very good spark, otherwise I find it hard to understand how you achieved what you achieved (being a foreman on many sites). I bet you going to buy some beer for them lads on Friday, aren’t you?
I Have argued that Jare it all comes down to single ph 3 ph new old confused EU wiring
as for SWA Grey is to be used as neutral as recomended by ESC to prevent confusing things If they dont like "Confusing" things WTF did they agree to change to bring us inline with those EU members who cant wire anything right anyways
Surely, the point is if it sleeved, there is no problem what you use. As long as both ends are the same.
The problem occurs when there is no sleeving, and assumptions are made, and we know what assumption is - the mother of all **ck-ups.
The problem arises when you put the sleeved black in the L terminal and the brown in the A terminal on the emergency fittings, while someone has fed the permanent live into the sleeved black and taken the brown back from the switch.
Either that or when you use prewired connectors where the manufacturer has wired brown to L and black to A, but the installer insists on doing it the other way around.
Can anyone explain how they wire non-emergency fittings if they're using black as switched live? Do you take a 4 core to the fitting and terminate the brown so you can continue using sleeved black as switched live? Bear in mind the NICEIC recommend any unused cores should be earthed, does this mean brown is now earth in part of the installation?
I think I can see your problem.
You are looking for an argument.
Unfortunately you've chosen the wrong subject.
Other than you, no one cares enough about the subject to argue about it.
As long as the same colour is used at both ends of the cable, it doesn't matter which one it is.
Reply to polarity argument at work in the UK Electrical Forum area at ElectriciansForums.net
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
