polarity warning on IMO isolators | on ElectriciansForums
Discuss polarity warning on IMO isolators in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
moggy1968
The guy that works for me doing some of the electrical bits connected one of the new IMO isolators the other day. When I checked on commisioning the polarity was wrong. rather than connecting in a stright line through the isolator the connection goes accross, so the top left input is continuous with the bottom right output, top right with bottom left.
I HATE IMO! Used them once and never again. To small and illogical layout. I like a bit of space around the isolator to allow for cable curving not cable cramming.
Guys,
On an AC isolator, it is physically possible to have the input and output of each pole in the same plane - the contacts separate in a 180degree plane away from each other. With a true DC disconnector, especially the IMO products, the contacts are intentionally designed to rotate/slide apart (or together) to minimise arc formation and to allow self-cleaning. These functions of the design are intentional as part of the unit's ability to manage load breaking DC current and to maximise the life-expectancy of the product.
If you look closely at the contact block/base, you will see that each pole (1-2, 3-4, 5-6 & 7-8) is actually stepped from each other - to facilitate this rotational knife-edge contact design.
Anyone using a contact block that has straight pass-through of contacts is more than likely looking at an AC contact block, not DC....
As for space inside the enclosures, this is a common observation, especially when running 2 strings through a 4-pole unit, and especially when running 6mm2 wire. However, IMO have listened to the marketplace and all new products being manufactured and supplied since the last couple of weeks now have the new, longer enclosures giving more working room inside and around the terminals.
Hope this helps,
Andy
Reply to polarity warning on IMO isolators in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
