Pool wiring, wago connectors | on ElectriciansForums
Discuss Pool wiring, wago connectors in the UK Electrical Forum area at ElectriciansForums.net
R
ryan24
Hi all
If wiring a pool on a 32amp breaker using 6mm cable for heater and wiring the pump of the same circuit. What would be the best way to join 3 x 6mm cables together in the junction box? The reason is the armoured in connected to heater then coming of that to feed fused spur for pump. Looked at using wago connectors but the heater is wired using flex which won't work on 6mm wago connectors
Thanks in advance
Hi all
Thanks in advance
Are you an Electrician or a enthusiastic DIYer, Ryan?
Still learning. Reason I ask is the pool is already wired but want to replace the junction box. Was wired with 3x6mm cables into connector blocks but doesn't look like great connections
yes it's in singles between the junction box and spur. Just wondering how everyone else would join the 3. Doesn't seem like a good connection all 3 in one connector block
I assume this is a TT supply, without any visual to see maybe install a small consumer unit/Dist. board not stated pool heater load for mcb size but 6A mcb radial to switched fused spur for pump.
Thanks for your reply. The problem with that is it's an above ground pool. And it's currently an ip rated junction box and spur fitted in a cupboard under the pool. Any good junction boxes with terminals good enough to take 3x6mm?
Reply to Pool wiring, wago connectors in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
yeah. i think so. Details here..... https://www.electriciansforums.net/threads/havent-seen-tel-for-a-month.210295/
