P
philtypet
Have a popping noise coming from the wall. There are 2 double sockets on the wall about 2 meters apart both of these have been changed to see if that would cure the problem. Popping noise is very random sometimes not heard for hours then can pop multiple times in a short period. Removed the new sockets and the back plate in the wall and the cables are drilled through the brick wall into the cavity and appear to go up towards the loft. No fuses blowing etc. The popping does not sound as though it's coming from the sockets but mid way up the wall. Any ideas what could be causing this?? Any advice much appreciated
Phil
Phil
