It does have a means of isolation, theres a big blue plug, and its more than 3mm when seperated. measured voltage was 240v on the nose, no need for 10mm, 6mm is fine its only a 30m run, ive ran similar lengths in new builds, properly specd etc
running cable through the kabin was not allowed as its pre-wired and fitted out with desk etc etc
Was MK 63A 5pin switched sockets at £300 a pop I believe. Alto ones were about £175 each, a fair bit cheaper but MK was specified.
Ah ok, I just checked on the system what we get the MK ones for and it £232.22. The Neweys ones are quite good tho, they have the quick term connections also
Email
Time zone
Last seen
Portakabin Electrical installation
sparkyork,
RISElectrical,
TrueNAS JBOD Storage Server
