Posh flood/uplight recommendations | on ElectriciansForums
Discuss Posh flood/uplight recommendations in the Lighting Forum area at ElectriciansForums.net
London
I've a money-no-object customer who needs three flood/uplights replaced. Any recommendations for a really solid, well-built unit that comes with a guarantee? I need these to look good and last.
Reply to Posh flood/uplight recommendations in the Lighting Forum area at ElectriciansForums.net
Tanking Recommendation Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking membrane, external tile board or...
Well conventional wisdom says that you just parallel ('piggy back') as many switch sources as you need, all fed to the contactor coil. If for...
