Possible borrowed neutral ring mains | on ElectriciansForums
Discuss Possible borrowed neutral ring mains in the UK Electrical Forum area at ElectriciansForums.net
TJC1
United Kingdom
Done a fuse board change on a propery, hasnt been touch since early 60s at a guess.
There is 2 ring mains, which i had split over the the 2 rcds. Each time i swithched on one, the other RCD tripped out, and vise versa.
Have no end to end on one ring main, and end to end on Line & Earth but not the neutral on the other ring.
To get it going for the weekend i put both rings on one RCD, but still tripped out.
Does this sound like a borrowed neutral problem, or a inter crossed ring main?
So then only one ring, which is faulty, which you energised anyway ?
Hello, Yes this would indicate a cross-connection between the 2 RCDs
If it only trips when you turn the MCB on, it indicates the line conductor that has been cross-linked.
If it trips instantly when you turn the RCD on, this would indicate a cross linked neutral.
A popular cause of this is lighting circuits, someone decides they want a new light and borrow a neutral from the nearest place and a live from some other circuit.
I presume you have Tested the insulation on both ring circuits and they checked out okay, if this is the case then my advice would be to remove all neutrals and earths from the board.
While the circuits are dead, IR test between all the cables, to ensure there is no connection between any cables there shouldn't be.
If there is, use the half split method to test and locate the connection.
Doing this should locate the fault efficiently so it can be rectified.
Hope this helps.
Obviously not... Just after some advice.
Well, I have to be very careful here, as I can come over as a bit of a negative old git. However, it does say in your profile that you are an "electrical contractor". So, my advice would be, next time, do what you are supposed to do, as an "electrical contractor", and don't get your self into this mess, as you obviously have no idea what the problem might be. Are you going to give your customer a decent discount for not doing a particularly good job, so far? Why didn't you do any testing? What testing are you going to now do, given the problem?? I would guess that you have probably made a very basic error when you put everything back together, which will now be a bit more tricky to resolve.Oh, and BTW, what is an "inter crossed ring main", when it is at home??
Think he is saying, maybe interconnection between both circuits.?
Well well well we're feeling the Christmas spirit in here today. Surely given the OPs responses the only reply he should be getting is 'come back when you have a set of test results'?
The way I think of it is we help this guy now, and someone looking for the same issue in the future finds his answer.
Reply to Possible borrowed neutral ring mains in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
