Possible failed RCD | on ElectriciansForums
Discuss Possible failed RCD in the Talk Electrician area at ElectriciansForums.net
Ipswich
Hi,
I would have thought it unusual for an RCD to fail? However, I have come across a Wylex WRS80/2 which gives >400ms reading for the 1X RCD test using a Megger 1552MFT. A no trip fail.
Could there be some other reason for this result?
Any help appreciated.
Regards,
Trenelly
It's protecting various circuits. My test was at a socket outlet.
The problem is usually a load with a capacitor still connected, such as a fridge or fluorescent light. The capacitor holds a charge for a period after power is disconnected and fools the meter into continuing to record voltage after the RCD has disconnected the supply.
As above, test the RCD with all loads disconnected.
Reply to Possible failed RCD in the Talk Electrician area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
