So, for a bit of completely pointless fun really, does this antique looking item that was acquired entirely for novelty/aesthetics value work, what is it for, and how accurate is it?
Until very recently I had no answer to any of those questions. It caught my eye at a car boot sale and I liked it. It just sat there looking cool, then we moved house, and it went missing. Fast forwards a year or two and some of the guru's on here started to talk about using a Wheatstone bridge to accurately measure a resistance and help with underground cable faults. The penny then dropped what it was actually for. A search through boxes finally found it and I felt compelled to try it out.
In a nutshell the principle is that the box has 3 variable resistors (top left, top right, and bottom three rows). The fourth resistance is the cable loop you want to measure.
When [top right] divided by [top left] = [cable loop resistance] / [bottom three rows] the voltage accross the middle will be zero.
So you effectively set the scale with the top row, 10 / 1000 in this case, and adjust the bottom three rows until you get as close to zero volts as possible.
My test was to try measure the resistance of this short bit of alarm cable:
The setup goes like this:
You set a value be removing pegs ( some are unfortunately missing so some holes are plugged with bolts).
A DC power supply of up to about 40v (I think) is connected to + and - . The left button connects the power, and the right button connects the measuring terminals to the middle of the bridge.
Here's a poor photo of the actual test with a 12v power supply and a voltmeter connected showing the bridge (virtually) balanced.
When a 10 and a 2 were removed from the bottom three rows, the bridge was very close to zero volts. So a value of 12 ohms balances the bridge.
The top row were set on 10 ohms and 1000 ohms.
So 10/1000=X/12
Or X=10/1000 * 12 giving a final result of 0.12 ohms.
So how did it compare to a calibrated MFT?
I was quite surprised, only 0.01 ohms difference. Not bad at all!
It can go back on it's shelf now and look cool again with my respect for it having increased a bit.
So 10/1000=X/12
