JP0704
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP!
Every so often (twice in the last two days) when running the hot water in the kitchen it trips our electrics (downstairs lights, sockets, cooker and boiler) and cannot be reset for a good 20-30 mins. This only happens randomly and when running the hot water. We have unplugged all appliances except cooker and it still happened. We have had an electrician out who said all is good (EICR done in July 2023 and all good) and had plumber out to service boiler and also run through cycles of high fire and low fire with no issues (this was completed during the daytime,
Not evening).
We have had the water pressure sensor changed but no change to trips.
When having a shower in the evening it has not tripped the electrics, it only seems to be when using the kitchen hot water.
Any advice greatly appreciated.
Jon
The electrician needs to come in the evening when you are able to recreate the fault. Assuming it is consistent in the evenings with the kitchen hot water on. It should be fairly easy to narrow down the item/leg of the radial causing the issue with an mft if the fault remains for 20mins or so at a time.
It was only put in yesterday. Not when they installed the board.
What was only just been put in, the mcb if not the board? When was the new board installed? and you dont have a test certificate yet?
Seems naive of you and the electrician to think a new board would solve the tripping fault.
Being on a separate RCBO will help minimise the inconvenience though and help locate it but you had already established it was the kitchen socket circuit.?
The RCB was only just put in.
The board was last week and yes we have the cert already.
The new board was not only because of the tripping but because the other was very old.
We couldn’t narrow it down before as it tripped the whole bank.
JP0704
Saffron Walden
United Kingdom
Potential boiler issue
JP0704,
JP0704,
TrueNAS JBOD Storage Server
