Potentially dangerous - should I report this to someone? | Page 3 | on ElectriciansForums
Discuss Potentially dangerous - should I report this to someone? in the UK Electrical Forum area at ElectriciansForums.net
SammyG
Greetings all,
I'm looking for a bit of advice. I'm not actually an electrician, but I am an electrical design engineer and I am aware of the regs.
I recently bought a new house which, after a few weeks developed an earth fault in the kitchen that kept tripping the RCD. No problem - I found the issue and fixed it.
However, whilst I was investigating this, I noticed that the sockets in my kitchen are not on a ring circuit, but rather in a radial circuit, with 2.5mm cabling, but the MCB in the consumer unit was a 32A. I believe that this was unsafe, so I replaced the MCB with a 20A.
Because I am a designer rather than an installer, I don't know how common this is and I don't really know how dangerous it is - theoretically, in fault conditions, the wire would likely melt before the MCB trips, but does it work this way in practice?
Also, I suspect that I am not technically supposed to tinker with my own electrics this way, so I am reluctant to go down any official channels.
I'd like to know if you folks here agree that this was dangerous, and if so, should I report the original installer to anyone (his name and number are printed on the consumer unit)?
Thanks in advance
Sammy.
Reply to Potentially dangerous - should I report this to someone? in the UK Electrical Forum area at ElectriciansForums.net
2 3
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
