Power factor question | on ElectriciansForums
Discuss Power factor question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
DT1878
revising for my 301 on Thursday and Ive come stuck on a question, any ideas?
A 30KW 3 phase delta connected motor has a power factor of 0.86 lagging. Calculate the line current.
answer is 50.35a but i dont know how to get there
thanks in advance :)
erm another quick problem.......
A medium sized factory has a three phase load of 50kVA and 30kVAr. Calculate the power factor?
a. 0.8
again im struggling with the formula, i must be arranging it in the wrong order, sorry to be a pain but anybody help us out?
Upvote 0
post the formulae, what is 30kvAr, should that read 30kvA, is 50kvA apparent power and 30kvA true power?
Upvote 0
well it will be this wont it?
The power factor for a three-phase electric motor can be expressed as:
PF = P / [(3)1/2 U I] (2)
where
PF = power factor
P = power applied (W, watts)
U = voltage (V)
I = current (A, amps)
Upvote 0
sorry i must be using the wrong forumula then, this is exactly how the question reads:
A medium sized factory has a three phase load of 50 kVA and 30 kVAr. Calculate the power factor
Upvote 0
to me, and im pretty sure im right(99.9%), you have a factory with apparent power 50kvA and true power of 30kvA, power factor=true power/apparent power, 30kvA/50kvA=0.6 which means your answer is wrong. text books with incorrect answers are not uncommon. does this sound plausible?? also i'm not sure what kvAr is?
Upvote 0
kvar is Reactive Power so i think the question is right im just not getting it. :confused:
or you could be right and the paper is wrong lol
Upvote 0
you are right, i didnt think you would that at level 3, i cant cope with these questions after a few beers so ill get back to you tomorrow nite if thats ok
Upvote 0
Reply to Power factor question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Received guidance from a logical soul on the Kawie Riders forum: Acc Fuse Block Power to BAT LOAD, install new cable from BAT LINE to AUX + (and)...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
Electrical Courses
