Power Keeps Cutting Out After New Fuse Box Installed | Page 2 | on ElectriciansForums
Discuss Power Keeps Cutting Out After New Fuse Box Installed in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is stairwell lighting into your fuse box, you need to
Flick switch, walk back and forward nine times wiggle flicking in between and possibly drop out
Neutral ata a time, and
Then maybe still rub the head
Hi I am training to become an electrician. I am just putting this out there for some more experienced electricians to maybe comment on.
The op said the switch controls a florescent tube, could it be that, it is the inductor in the tube causing the RCD to trip. I am wondering if it has anything to do with the inductor in the florescent tube inducing a current in the neutral conductor when the magnetic field around it collapses, after the switch has been flipped. This could cause a current more than 30mA in the Neutral and not in the Line and therefore trip the RCD?
Is there a simple test he could use to see if this theory holds any weight?
Reply to Power Keeps Cutting Out After New Fuse Box Installed in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes, it was new from ebay yes new from ebay, on the picture it looks right till it comes. Like you said, fake
Is your dimmer rated for 1200 watts?
