Power Posts/Poles
David.
evening fellas,
a manager from another site at work rang me asking to pop over and check out a quote he was given.
Anyways, 8 IP rated sockets on a kitchen floor (office block). They keep getting damaged by staff so they want these removing and a power post fitting however they want 6 IP rated sockets on the post??
I have seen power posts in offices for computers etc with normal socket fronts on but never in a kitchen or with IP rated fronts? Has anybody come across this before and if so where should I be looking? Would normal IP front fit?
Also anything in particular I may need to know about fitting these posts? Never done them before. And to make life exciting, its a raised access floor (so i've been told) with board over the tiles and then sealed vinyl on top :(
