Power Supply to Shed | on ElectriciansForums
Discuss Power Supply to Shed in the Talk Electrician area at ElectriciansForums.net
M
mikeevans1004
Alright team! Can somebody please point me in the right direction?
Looking to run a SWA cable to my shed from my garage in order to power 1 double socket and 2 LED lights. Shed is less than 10 meters from garage. I plan to run the SWA cable directly to the socket then from the socket to a fused light switch with a 3 amp fuse. Entire house has been recently re-wired and garage is on its own ring main on a 32 amp breaker at my consumer unit. Garage ring main currently only has 3 double sockets which power a freezer, fridge, washer and dryer and occasionally some power tools and what-not.
First Question: Can I spur off my garage ring main with the SWA cable and if so, which is the best way to "break in" to the ring main.
Second question: What size cable do I need?
Any advice would be greatly appreciated!
Hi Welcome to the forum :)
As a forum we are all for helping a fellow tradesman even if your electrical origins were experienced elsewhere but you seem to be asking us for a step by step guide here, if you would show us your thoughts and calcs for the SWA + you chosen install methods then we would be more than pleased to confirm and/or correct your calcs and methods, simply asking what size cable without any additional info would mean we are only guessing too.
Just a few questions to get the ball rolling -
Can we assume the garage ring is RCD protected?
Are there any other services coming into the shed or is it just a wooden hut, typical gardeners shed?
Would the socket be used for a heating load?
To avoid certain members 'going off on one' I would use the correct term 'Ring Final Circuit' rather than 'Ring Main'. Daz
helmets are usually (non-combustible) steel . tin maybe used as an anti-corrosion coating, but is pretty useless at stopping shrapnel.
  1. Tin
    Chemical Element
    Tin is a chemical element with the symbol Sn and atomic number 50. It is a main group metal in group 14 of the periodic table. Wikipedia
    Symbol: Sn
    Melting point: 231.9 °C
    Electron configuration: [Kr] 4d[SUP]10[/SUP]5s[SUP]2[/SUP]5p[SUP]2[/SUP]
    Atomic number: 50
    Atomic mass: 118.71 u
    Boiling point: 2,603 °C
    Electrons per shell: 2, 8, 18, 18, 4
  1. Tin
    Chemical Element
    Symbol: Sn
    Atomic number: 50
Gawd!! .... Just wot we need - a Scouser with a GCE O level.
@ the OP Mike, this seems to be a little bit over your head going by the questions you have asked. You really need to get a local electrician in that will design this or install it for you.
i have an A level with distinction, abbreviated to AW, which in practical terms refers to Alloy Wheels.
Reply to Power Supply to Shed in the Talk Electrician area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
Yes, relatively common, especially in rural areas, once upon a time. The bare overhead lines would be hard-drawn copper and supported on porcelain...
davesparks
