Power Switch 2 input, 1 output | on ElectriciansForums
Discuss Power Switch 2 input, 1 output in the UK Electrical Forum area at ElectriciansForums.net
jackp20
Statesboro
So I just got a subwoofer in my truck and I want to wire a strip of led lights to flash with the bass, but at the same time I want to be able to just turn them on and off at full brightness. Im wondering if there is something I can buy that has two power inputs that I can hard wire into, and output for the led strips, and then a switch that can change from the bass power level or the straight on and off power.
Hi Jack and welcome to the forum Why don’t you see if they make a timer for 12vdc which could possibly be set to come on with base and blink and you will probably have to add a monitory switch to control them
Hi Jack, what you want is called a changeover switch or single pole double throw switch.
Any auto electrical shop could sell you one. It will have three terminals, probably called 1-2-C or NO-NC-COM or similar.
You would wire the bass controlled wire to one contact, the straight 12V power to another, and the common terminal to your LED lights.
**there was a switch diagram here, but the forum software collapses multiple spaces so the arrangement was wonky
EDIT: As Megawatt said, you will also need something to switch the signal to the LED lights in time with the bass. Some amps may have a specific output, I would talk to whoever supplied your sub or an auto-audio shop for more info.
Reply to Power Switch 2 input, 1 output in the UK Electrical Forum area at ElectriciansForums.net
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
