HI Can anyone please advise me on the correct rcd and cable for power to my shed
I would like to run a power lead from the consumer unit to my shed , my unit has RCBOs, should I use a 16am RCD A / B or RCBO from the main board? This will then go to my shed into a 2 switch consumer (shed unit) also what size cable should I use. I know I should use SWA but I would run this above ground and along a wall and I will also put this inside cable trunking, so would normal 6mm twin & Earth cable be ok?
I will be running the following in my shed
Freezer
Tumble dryer
2 Sockets
2 outside light and 1 inside
Freezer
Tumble dryer
2 Sockets
