Power to shed | on ElectriciansForums
Discuss Power to shed in the UK Electrical Forum area at ElectriciansForums.net
england
Hello all ,
I’m currently in the middle of readying my garden for next summer , basically I want to put power into my shed. running a 4mm armoured from the house to the shed and into the board inside the shed. The boards that are on sale have a 40amp main switch and then the two breakers for sockets and lights. My main question is what size breaker should I use inside the house for the power ? I was going to use 32amp… this is being done by a professional but I’m just pricing it up and getting a general idea.
I don't like cables clipped to a fence panel , looks naff and if the panel gets blown down it pulls all the cables out of place
Reply to Power to shed in the UK Electrical Forum area at ElectriciansForums.net
BTW, the LD at the house will be 1" to accommodate the 6/3 coming from the house. Will use a 1" to 3/4" adapter to neck down to the 3/4" conduit...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
