Power to tail light problem | on ElectriciansForums
Discuss Power to tail light problem in the Auto Electrician Forum area at ElectriciansForums.net
possible bad earth, maybe on another light in either rear cluster. check for corrosion
Bad earth to light cluster and "something" is pulling the cluster "earth" up towards 12V ? When you switch lights on, the lamp goes out because it's now between 12V and 12V.
Probably not full on and off - more likely dim and dimmer.
You see it a fair bit where a tail light is on but goes off when either brake or indicator is used - with brake/indicator light not coming on.
So first check, measure voltage between earth on the light and chassis.
Reply to Power to tail light problem in the Auto Electrician Forum area at ElectriciansForums.net
Ok, after trying two different flashers supposedly for Led bulbs, I got one that also has a ground wire, and it worked. I now have operating turn...
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
