Power used by an oven
Bloody hell guys this is supposed to be a friendly site, I should report you all for pointless and offensive posts hahaha
... I don't know why you waste your time on here trash talking like you've never needed help before. Don't you have a regs book to read and memorise? Whatever floats your boat and gives you that semi hard on you crave I suppose!
Thanks, that's all I needed, 32A, good lord!
All you had to do was look at the specs on the beko website. Bit of common sense.
Diversity......was'nt that them shadowy people on Britains got talent cant remember them making a shape like a oven
you're thinking od attraction. hungarians. won BGT.
@ OP. loads of threads on this forum about cooker diversity. use your search function.
They cant of been all the time or they wouldnt have had any diversity ;) must have been x factor sounds like diversity factor
Maybe we should all report you for a pointless and offensive question?
What do you expect from such a basic question? (One which I would of known the answer to before starting my apprenticeship!) As someone who claims to be an electrician you should know the answer to this! Maybe you should actually open up your regs book one day!
I don't have an OSG or a regs book and I didn't do an apprenticeship either, I'm not even qualified I'm just winging it lol.
If the question was so basic then why bother come on here? The original question was can you work out kW given kWh, which none of you smarty pants have answered! (I'm only referring to the cocky lot)
The energy E in kilowatt-hour (kWh) is equal to the power P in kilowatts (kW), times the time t in hours (h).
E(kWh) = P(kW) · t(h)
I could've waited until the oven was delivered and work it out myself and possibly get my sister to return the oven if the demand was too large for the already installed circuit. However because up until now I've been met by intelligent responses I thought I'd come on here instead. Jheeze! Some of you really need to chill out and stop taking things so seriously. And before you say incompetence is serious OF COURSE I'VE COME ACROSS DIVERSITY, they lost to Su Bo didn't they? Hahaha
Prime Design,
dan86,
