M
markus19
Hi guys
I have just bought a use hydraulic oil pup that runs from a 12v motor
I didnt have a 12volt battery to try it with but i had a 240v to 13v 5amp
Inverter i wired it up via the solenoid but just got a few clicks from the
Solenoid
I then ran a 30ft cable from my 12v battery in my van to the solenoid
But this time just got rapid clicks but no motor kicking in
I then trying wiring direct leaving out the solenoid ... nothing...
i then took the motor off the pump and plugged it direct onto the 12v van battery it fired up
what could i use to power the motor from a mains connection e.g what amps or watts
thanks
Solenoid
thanks
