powering 12v motor | Page 2 | on ElectriciansForums
Discuss powering 12v motor in the UK Electrical Forum area at ElectriciansForums.net
M
markus19
Hi guys
I have just bought a use hydraulic oil pup that runs from a 12v motor
I didnt have a 12volt battery to try it with but i had a 240v to 13v 5amp
Inverter i wired it up via the solenoid but just got a few clicks from the
Solenoid
I then ran a 30ft cable from my 12v battery in my van to the solenoid
But this time just got rapid clicks but no motor kicking in
I then trying wiring direct leaving out the solenoid ... nothing...
i then took the motor off the pump and plugged it direct onto the 12v van battery it fired up
what could i use to power the motor from a mains connection e.g what amps or watts
thanks
hello
i am wanting to use the pump for a ram to split
logs
so i would say around 1 - 2 hours
regardless of how long i want to use it if
i wire it to a battery the battery gonna need charged
which i dont want to do
thanks mark
The only way you're going to get this sorted if wire it up to a battery and try it under the conditions that it'll be used, ie splitting logs. Measure the maximum current drawn off the battery. Then buy yourself a 230V to 12V DC power supply of an adequate rating. This is likely to be expensive.
Alternatively, run it off a car battery, which will provide quite high current for a reasonable length of time (duration dependent on battery size). Then you'll only need a small, cheap, charger to keep it topped up.
lol
yeah a bought this unit quite cheap without having a good look i was hoping the motor
would be 240v
but it has turned out it isnt...
the unit was the
spool valve
piping
hydro tank
hydro pump
and 12v electric motor
i was hoping i could run it from my generator as it has a 12v output but its only rated to 8.2 amps
which likely wouldn't be enough to power it...
I can pretty much guarantee this motor will draw way more than 8Amps. If you connect it to your generator 12v output you'll either cause the protection to trip or damage the generator. I'd strongly advise against even trying the genny, stick with a battery.
so can you buy such a device that converters 240v to 12vdc 50/60amp ?
what would you say the wattage is on the motor ?
thanks
thanks
You're not taking this in are you? We don't know what the rating of the motor is, and we don't know how much current it will draw when used in your particular application. It will need testing, as I said previously. If you don't have the means to do this yourself, you may need to find an electrician (perhaps an automotive-electrician) who has a suitable DC ammeter, to test it for you.
Yes, you can buy a 12V 60A DC power supply:
Buy Embedded Switch Mode Power Supplies (SMPS) RSP1000 Series SMPSU, 12V 60A RS RSP-1000-12 online from RS for next day delivery.
I'm not saying that this particular one is suitable for your purpose.
yeah but i though after i sent the link with the same motor as i have
someone would be able to till from it
New Pump Hydraulic Motor Monarch JS Barnes Waspa 12V | eBay
There are no electrical specifications on that listing (except for 12V).
Try sourcing a 230V motor with the same shaft and mounting to directly replace your existing 12V motor, should be around ÂŁ150, cheaper than a high current power supply, but more expensive than 2 12V batteries and battery charger.
Do you ever get the feeling that you're just farting against thunder here??? :rolleyes4:
You will not get ANY kind of duty cycle with the set up your suggesting. If i had read "log splitting" earlier,i would have said not to bother. Any mains powered hydraulic unit will have a return circuit for cooling,and open centre proportional valving to ensure you get two hours of fun...put it back on ebay and let someone else feel disappointed.
so what are theys unit made for then if there no good to run a ram in and out for a couple of hours ??
Reply to powering 12v motor in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Inverter leads do tend to be quite meaty. An extension cord won't survive I wouldnt have thought
