Powering a hot tub off a 13A socket.. | Page 3 | on ElectriciansForums
Discuss Powering a hot tub off a 13A socket.. in the UK Electrical Forum area at ElectriciansForums.net
T
tkm16
Hi,
I have recently been given a hot tub which is powered from a standard 13A plug. The manual says to connect it to a 13A IP66 socket which I currently don't have. I have been told I could just run a spur off the downstairs ring main to a IP66 socket outside, is this correct? I mean i'm no electrician but I thought will all the kitchen appliances etc wouldnt adding a hot tub overload the ring main?
Thanks!
This is my one, its at the pointy end if you look closely.
My missus was on about getting a hot tub a couple of years ago, I agreed but said the only place I was willing to have it was in the cellar. She changed her mind.
Wouldn't need Pampas Grass there though?
Or you could have one like I have on my boat. Sorry about the double pic, couldn't afford two!
Reply to Powering a hot tub off a 13A socket.. in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
