Hi,
Hope someone could help with below situation or recommend a good forum to ask about or find information on as I read a lot on the forums and watched many videos but it just got very confusing.
Objective
Information gathered, parts on hand
Questions
Thank you in advance
Objective
- We acquired 7 sets of led sugar canes, each set has 40 Red leds and is powered by 2 AA batteries. I would like to be able to power them all at once with 2 dc adapters and need to know what would be the safe voltage and amperage for 3-4 sets of 40 red bulbs.
- I measured the current between second battery positive terminal and wire that led to led lights 0.008A = 8ma
- Voltage when off was 2.95 volt, voltage when on was 2.85 volts.
- There is no constant current or constant voltage regulator, just connection to 2 AA batteries
- I also have 36 volt 0.235A, 5 volt 700ma and 12 volt 2.5A dc adapters available if it is better to connect all the products in series.
Questions
- I have ordered 2x 3 volt dc adapters with fake batteries but not sure what amperage and thought to wire 3-4 sets (each 40 leds) to each in parallel circuit as they are all the same model/product led lights. Is it achievable?
- What resistors do i need to add if any to prevent leds drawing extra current available from dc adapter and burning themselves, i am not able to check if existing leds have resistors somewhere due to their locations inside plastic sugar cane?
- Providing leds have resistor can i use below formula to calculate resistor to add to parallel circuit that will connect 4 sets depending on dc adapter? (adapter voltage - sum of led forward voltage for each set)/sum of currents e.g. (12 - 8)/(4*0.01)=100 ohm
