Powering neighbor fault | Page 2 | on ElectriciansForums
Discuss Powering neighbor fault in the Australia area at ElectriciansForums.net
stavvie
Hi,
Been to a house today to sort out hallway light that was not working. As I was doing a safe isolation with my continuity/voltage tester I was getting continuity between the ring main live and neutral, ring live and earth and ring live and lighting neutral. So I wanted to do a further investigation and carry out a r1+r2 test and insulation resistance test. (this is a TN-S earthing arrangement and the CU is an old rewireable CU).
I took out the main supply fuse to isolate it completely as I did not trust any of the electrics now. 2 minutes later there was a knock on the door and it was the neighbor asking if the power was out in this house. I told him I turned the power off as I was working on the elecs and told him that his power should not have turned off. I stuck the fuse in again just to confirm that it was connected to his elecs and to my amasement it was.
I couldn't carry out the test's I wanted to because I didn't bring the right leads with me as I forgot them. So will be going back next week.
Any suggestion? or has anyone come across this before?
Cheers
Reply to Powering neighbor fault in the Australia area at ElectriciansForums.net
Oh dear, I missed the date!!!
Yes, think I will disconnect it again as the 16A protection makes it okay to leave it. Out of caution, check the Electrical Cert. All I've done...
