Powering Sub Board | on ElectriciansForums
Discuss Powering Sub Board in the UK Electrical Forum area at ElectriciansForums.net
A
allybally
Hi,I am on a job and at the moment there is a 10mm T&E powering a sub board in a flat downstairs, I am rewiring the whole house but this is the 1st time ive come across this, the Ze at the main board is 0.30 and im allowed 0.35, what size and type of cable would you run, a couple of the guys at work are saying 25mm 3 core swa, do you think this will be the case, im going to be powering this sub board from a 100A switch fused from a phase block, any suggestions would be much appreciated,
Many Thanks
What size is the incoming cut-out fuse? 100A max. Down rate the fuse in the switch to 60A and use 16mm. A flat doesn’t take that much even if a shower is fitted.
I’ll bet I could run my flat off a 16A fuse.
Reply to Powering Sub Board in the UK Electrical Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
