pre Jan 2016 boards | on ElectriciansForums
Discuss pre Jan 2016 boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
east sussex
Hi there I've been asked to start to carry out a number of Landlord certs, which I have started. I was just wondering what you guys were saying about non metal boards, if there is already a full RCD board installed pre Jan 2016. Are you doing unsatisfactory? or just putting them down as a recommendation and making them satisfactory?
Have a look at best practice guide 4 from Electrical Safety First:-
http://www.----------------------------/mediafile/100740439/Best-Practice-Guide-4-Issue-4-.pdf
It recommends that if the board is combustible, is not within a non-combustible enclosure and is located under a wooden staircase or is in the sole route of escape it's a C3, failing that it doesn't get a mention. If unsatisfactory connections are found inside during inspection, it's a C2.
It's all in the best practice guide.
Reply to pre Jan 2016 boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As it was explained to me, you can write anything in the book so long as it already exists in the book somewhere in original print. Tabs, etc are...
Your biggest mistake is admitting to a mistake.... If theres no witnesses, it didn't happen. However.... A few golden rules.... Never trust...
