Precast concrete garage | Page 2 | on ElectriciansForums
Discuss Precast concrete garage in the UK Electrical Forum area at ElectriciansForums.net
robd
East Anglia
Hi all,
A bit off topic but I am looking at getting a precast concrete garage at mine and wondered if anyone else had one or any thoughts on them?
Was going to brick build one but think it's too expensive for what I need it for.
Thanks in advance
Not really Rob, just a proper heavy duty shed done in 3 x 2 tanalised timber. There are usually specialist shed companies around who will quote and build to your requirements as well as supply the more 'standard' sizes.
Timber is a nice idea but you have to worry about premature deterioration of the building itself if it's not detailed properly. With concrete it will spall eventually and the rebar rust, but it will deal with being wet very well. Also it's more secure if that's a concern (notwithstanding the door and roof)
My thinking was I wouldn't have to treat the concrete every year like I would with wood and also the concrete would be more secure. The concrete isn't perfect though which is why I've been umming and ah-ing for a few months now
Ref security one of the ones I looked at before has a metal personnel door as the only way in though I do realise if people want to get in they will usually find a way
If you are looking at a dehumidifier, get a proper installation unit with a drain, as opposed to a plastic domestic one that you have to empty manually.
We've had a few units from Ebac Industrial Products - decent, well built equipment and you'll be astounded how much water they extract each day. Get a cheap hygrometer and run that for a while first to see that you actually need to extract - then watch the relative humidity drop magnificently once you're running a unit in there.
Reply to Precast concrete garage in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
First time doing a patio Hi guys, had some great advice here before so thought I would ask here for advice again regarding porcelain patio...
Sean-tries-to-tile
