Price rewire 3 bed (customer to chase) | on ElectriciansForums
Discuss Price rewire 3 bed (customer to chase) in the Australia area at ElectriciansForums.net
Swansea, South Wales
Hi guys just woundering a fair price for the following 3 bed rewire (customer to chase walls) was thinking ÂŁ2400? thanks guys
Note: all accessories in standard plastic unless otherwise stated
Electrical Supply
· fit 17[SUP]th[/SUP] edition consumer unit(customer supplied)
· New 25mm2 main tails
· Gas and water earth bond 10mm2
· RCBO for smoke detectors (required by regulations)
· New main Earth 16mm2
Living room
· 3x double sockets
· 1x 1gang light switch
· 1 x pendant light
Dining room
· 2x double sockets
· 1xlight switch
· 1x 1 gang light switch
Kitchen
· 1x 3gang switch
· 3x lights (customer supplied)
· 6x double sockets
· 1xsingle socket cooker extractor
· 1x cooker switch and supply
· 1x cooker connector plate
· 1xoven feed
· 1xoven switch
· 1xmains interlinked heat detector
Out House
· 1x 2gang light switch
· 2x pendant lights
· 4x Double sockets
· 1x Pir bulkhead light
· 1x 150w Pir security light
Storage out house
· 1x double socket (trunking)
· 1x light switch (trunking)
· 1xpendant light
Downstairs hallway
· 1x Double socket
· 1x 2gang switch (2-way landing)
· 1x pendant light
· 1xmains interlinked smoke detector
Upstairs Landing
· 1x light switch (2-way)
· 1x double socket landing
· 1xlight
Toilet
· 1x light switch
· 1xpendant light
Bathroom
· 1x pull switch
· 2x bathroom lights (customer supplied)
· 1x Fan light(customer to vent)
· 1x pull switch for fan light
Bedroom 1
· 2x double socket
· 1x double socket TV
· 2X pendant light
· 1x2 gang switch
Bedroom 2
· 2x double sockets
· 1x light switch
· 1xpendant light
Bedroom 3
· 2x double sockets
· 1x light switch
· 1xpendant light
Attic
· 1x Batton Holder light
· 1x pull switch
Warranty
· 12 month warranty on materials supplied
· Insurance back warranty through NICEIC
· Genuine NICEIC electrical installation certificate
· Installation Part P Registered
Note: Customer to chase walls for cable routes for electrical accessories.
Does your client know which CU to buy if you're planning to add a RCBO? and as above why the RCBO, I'd be running it off one of the lighting circuits.
Also think the price may be a bit high for South Wales.
Sounds about right! i hate the customers getting involved though! dont forget to stick a bit on for having to go around all the customers chases afterwards where there too shallow/too deep/cementing the back of the socket chases where theres nothing to fix a box to etc etc etc
Id leave out the RCBO, are the smokes Batt back up?
Yeah its a wylex high integrity board. iv always ran them independantly on there own circuit from the main switch rcbo, niceic inspector thinks it a good idea also .personal preference i can see where your coming from if your lights are out then your smokes are out and you know there not working. but then if youve got a fault on one rcd then the smokes are not working and they could be needed in an emergency.
I thought smoke detectors needed a seperate independent supply ? so cannot be taken from the lighting circuit ??? I might be wrong
I dont have the green updated edition. But it WAS ( is?) preferred to put on the lighting circuit. Customer then knows power to alarms are off and also discourages end user from switching off when tripping and forgetting to put back on.
for domestic grade D smoke alarms you can supply from a lighting circuit and on an RCD if they have a standby supply eg battery back up.
If you are installing a grade C system or above this needs to be on an independant supply
you wont find this in the BGB it will be in the building regs or bS5839
if hes happy to that give him the back boxs red wall plugs 5.5drill bet and tell him go a head then if he f/up then he knows who to call then......make sure you give him the gromet
Reply to Price rewire 3 bed (customer to chase) in the Australia area at ElectriciansForums.net
