Pricing for a rewire-high likelihood of asbestos | Page 2 | on ElectriciansForums
Discuss Pricing for a rewire-high likelihood of asbestos in the UK Electrical Forum area at ElectriciansForums.net
MFS Electrical
Mentor
Nearly Esteemed
Scotland, Inverclyde, Greenock
anyone had an asbestos survey done average price for it and what kind of building it was you had done? Also which type did you do construction and demolition or just the management?
Sort of under the impression that you’d go management first and if asbestos is suspected/found then Construction and demolition would be next on the list?
Working on things like asbestos containing artex, asbestos cement sheets, even asbestos insulating board can be done quite safely if you follow the guidance from the HSE and get yourself on a non-licensed works course, very informative.
I've done a rewire in a house with asbestos in artex on every wall and every ceiling.
Cost about ÂŁ300 to get rid of the asbestos waste (6 bags if I recall correctly - mainly materials used during works, but also included vacuum cleaner left in the house that appeared to have been used to clean up artex), about ÂŁ20 in disposable overalls, good quality facemask with FP3 filters and a FaceFit test was about ÂŁ60. I hired in a class H vacuum cleaner (for cleanup of possible waste - already there - and dust extraction when drilling the walls).
Took me about 3-4 days to cut all the holes in the ceiling and drill all the screw holes for fixing the trunking. I would go about it this way as if you stick it to asbestos containing materials there is a chance it will damage the material if it's bumped. PVA adhesive to paint on/around any holes you cut drill, to seal the edges. That sounds like a long time, but in a disposable overall with a respirator on it's hard going especially when you think about what you have to do (basically, setup a clean working environment, do the cutting/drilling and then cleanup everything before moving on). If you're cutting bigger holes, include some bog standard wall paper paste in the price and possibly some new hole saws/arbors (the paste gets everywhere).
So those are the costs associated with working with it. Materials, there is the obvious cost of trunking. I used countersunk screws with cup washers to help spread the load when fixing the trunking.
Insurance may be an issue... I found insurance to do even non-licensed works prohibitively expensive, so suffice to say I had a chat with the client and we came to an understanding.
In terms of the survey, I think the bill was somewhere in the region of ÂŁ400. The guy doing the survey met me on site and we had a chat about why it was needed and he sampled everywhere I was planning on cutting a chase. I think it was the demolition/construction survey. Obviously it came back as positive everywhere.
Would I do another one? I would consider it because if you set yourself up with the right gear, it's fairly easy and straightforward. There are companies that will hire you the gear you need and I found they were very helpful. They'll also supply waste bags and disposable overalls, with the later being much cheaper than buying from say ScrewFix.
Hi. Are you interested in work in the S. London area? Please let me know electrics"at"exerhost.com
It should be standard practice whenever you think you might encounter asbestos containing materials
Yep,
Unfortunately this could equate to nearly all "re-wires" in the UK. The use of ACM's (asbestos containing materials) was banned in the UK in 1999. The use of asbestos was especially rife in the 60's,70's & early 80's slowly declining in the mid 80's - 90's So this may mean that the vast majority of properties that are worked on, especially for re-wires will have some ACM's present. I remember when I did my non licenced course, anything earlier than year 2000, in theory, should be surveyed prior to any demolition / alteration works.
Reply to Pricing for a rewire-high likelihood of asbestos in the UK Electrical Forum area at ElectriciansForums.net
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
