pricing tips | Page 2 | on ElectriciansForums
Discuss pricing tips in the UK Electrical Forum area at ElectriciansForums.net
GPack
Can anyone give me any tips on pricing a new build?
All points are marked on the archiects drawing.
I can count up the back boxes, sockets, pendants etc
I can also measure the cable required from the plans
When you price per point I take it you include the cost of the fittings. Do you also take the cost of the cable into the point?
Would really appreciate your experience on this one.
consider how long will each point will take.
is it at a comfortable working position or are you working off steps or in a restricted position.
the type of structure you are installing the point into. masonry /lath & plaster/plasterboard etc.
ease of cable run. are you using existing runs or starting from scratch
add cost of cable,accessorys,cable clips,grommets etc
work out average cost per point. x number of points. add ??% for the unforeseen
When costing a job up i usually do it both ways. Price per point and then do it again by using the materials plus mark up and labor. Occasionally both match up which means I know i'm spot on but otherwise I'll know whether I am there or there about. A builder who I do work for always asks for price per point and it sometimes comes in more expensive, but that's his fault and my gain unfortunately.
Reply to pricing tips in the UK Electrical Forum area at ElectriciansForums.net
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
After fitting out the first room of downlights.... i expect him to get a bit speedier at fitting them There is so many unknowns to price at this...
