primary current calculation | on ElectriciansForums
Discuss primary current calculation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
trebor
First question from the 2391-20 this week
18 x 24 volt soldering irons to be supplied by a transformer via elv sockets, what is the design current of the primary circuit
i said the secondary load was 360va so choose a 400va transformer
the primary would be 400/230 = 1.73A, am I wrong or really wrong
can't see how you can calcx. the va as you are only given the voltage of the irons, not the wattage.
can't be. wouldn't get even warm at 1.2watt. the q. just says 18 24v soldering irons. no mention of wattage or amperage.
Thats 15A on the secondary so the primary current will be
15A x secondary voltage/primary voltage = 15 x 24/230 = 15 x 0.1 = 1.5A
Reply to primary current calculation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
