primary current calculation | Page 2 | on ElectriciansForums
Discuss primary current calculation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you take the soldering iron wattage of 18 watts even though its a transformer the primery current will be roughly the same as if it was 230 volt , reason for this is the lower the voltage the higher the current , so if you have you 24volt 18 watt soldering iron the current on the secondary will be 0.75 amps but the primery wattage would be calcultaed by using the same method but 230 volts so 18 /230 0.078 amps so if you have 20 soldering irons at 20 x 18 watts = 360 watt so 360 / 230 = 1.6 amps
i'd calc. by the wattage 360w/230= 1.565A, then allow for losses ( 5% ), design current =1.65A.
Now thats wet everyones appetite heres the rest attached, perhaps Lenny can move it somewhere more suitable
  • 2391-20 June 2011.pdf
Reply to primary current calculation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
