primer peeling Discussion Thread | on ElectriciansForums
  • Thread starter chequers
  • Start date
  • Replies 0
  • Views 158
Discuss primer peeling Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
primer peeling
Ok applied pr360 primer in three coats .first few tiles have been laid .the primer is peeling off this morning whilst picking the adhesive snobs that have squirmed out on the floor .its like a skin .not a good start . The tiles are large and it is s anhydrate floor .what will happen in the future a with the tiles or b if there is a small missed peel
primer peeling for the Original Article on Tiling Advice Forum
Reply to primer peeling Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
N
Primer or SBR ? What does everyone usually use ? Such a mix out there!!!!!!! Primer or SBR ? for the Original Article on Tiling Advice Forum
NHannaford
N
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t...
