Private rented accommodation, Scotland | on ElectriciansForums
Discuss Private rented accommodation, Scotland in the Talk Electrician area at ElectriciansForums.net
polo1
Glasgow
Question for primarily electricians working in Scotland. In, for example, a two story semi-detached property, are you installing smoke detectors in both the lower and upper hall or in just the upper hall.
My understanding was that both the upper and lower landings had to be covered (as well as living room and a heat in the kitchen). My practice has been challenged by another electrician, who thinks only the upper landing requires a detector.
The Technical Handbook Domestic says ... " at least 1 smoke alarm in every circulation space such as hallways and landings....". The standard in new build is both lower and upper landings.
Should both landing and hallway....only time you would used landing only, would be on a complete open staircase, were smoke would rise to the highest point.
Thanks T. In a typical 2 story domestic dwelling, smoke finding its way into a lower hall would inevitably then migrate to the upper landing. I guess I'm looking for a definitive interpretation of the regs/ tech handbook. I've been clear that both the lower hall and upper landing should be covered, but realise I can't find the specifics written down.
You could argue that the stair and front door is the escape route. And that if there was a fire down stairs, by the time the smoke has reached the upper landing detector, the stairs could be impassable.
Hum..... I think 1 on each floor is the best solution - as for just one on the landing - could it be too late when that one goes off?
Best way to explain this, is to think about rising smoke.....in a normal house, smoke would be trapped by the lower or hallway ceiling, filling the area before rising to the next level ceiling. As pointed out, this is valuable escape time being used. so 100% detector on each level.....A big open grand staircase, you would only come across in a mansion, would be a straight, unobstructed void to the next level, allowing smoke to rise instantly to the highest point, the top level ceiling. So this would be the only time a single detector would b used.
Circulation space and not more than 3.5m from any doors to other rooms.
also if you have drop in ceiling height through beams or arch decoration , if beam more than 10 percent it requires another.
Reply to Private rented accommodation, Scotland in the Talk Electrician area at ElectriciansForums.net
