private supply cable 400 metres from meter | on ElectriciansForums
Discuss private supply cable 400 metres from meter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
beefheart
hi
Ive got a customer that has a meter position about 400 metres from there house intake, they want to install an groundmount system that is then 218 meters from house, i can account from for the pv side but what does everyone think about the supply side, admittedly this has only come to light via email so i will need a more in depth site visit to check the cable and exact length, anything else i should consider, what should I look out for ?
Try the SunnyDesign software. voltage drop will be your biggest problem (oh! and put the gen meter near the inverter :) )
With our recent experience You HAVE to make some serious cable calculations and voltage readings before making a decision and the cable calculations HAVE to be made right back to the origin of the supply. The generation meter next to the inverter is good idea and good practice however VD and high voltage will mean the inverter WILL drop out at peak generation times. Don't rely on a sub main being suitable not only for load but it would not of been designed factoring in the <1% VD (if designed at all!) See my post on Diehl AKO Platinum 3800S Dropping out. 250mts @ 50mm. Not enough.
Reply to private supply cable 400 metres from meter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
