Problem Ceiling Light | Page 2 | on ElectriciansForums
Discuss Problem Ceiling Light in the UK Electrical Forum area at ElectriciansForums.net
dpooley85
Hi all, i have replaced a set of two ceiling lights and having some problems with them.
They are both on the samr switch and have identified the switched live but no matter which way i wire from diagrams on other sites or books only one light stays on permanantly whether the switch is on or not and it is the last one on the circuit.
I have gone from using a connector block to a ceiling rose and seem to remember having to connect a neutral and live together to bypass the first light. Could that be my problem?
How do i get both lights working at the same time with the switch, any ideas or suggestions welcome as i am getting really annoyed with it.
Cheers
LOL - this reminds me of a neighbour (or rather, his wife!) asking for my help with a simple installation of a kitchen under-cupboard strip light.
He explained that he nearly had it right: when the switch was on the light was on. And when switched off the light went off, but curiously it wouldn't come on again until he reset the MCB. And he couldn't reset the MCB with this light switched off either.
Opening up the switch found he had wired supply and load neutral to common, supply and load phase to L2, and finally supply and load cpc to L1. Very neat. Fortunately there was no RCD present, or it would have all been a lot less fun.
His wiife said he'd spent most of the day trying various combinations of wires in the switch. I could only guess at how much exercise that 6Amp MCB had had that day!
Sorted his wiring for him. And his misses sorted me with a very splended Rioja Gran Riserva a few days later, which I suspected might have been bought with the proceeds from her selling the contents of his electrical tool kit......
didnt go quite to plan, first light on when switched on and vice versa and second light stays off permanantly. had wiring checked and all is pukka in that respect.
the mystery deepens.
called various ppl and cant seem to phathom what ive done wrong or whether its a dud light
anyone got any ideas before i call the local electrician?
Read post #13 again. It ain't that difficult
[ElectriciansForums.net] Problem Ceiling Light
Reply to Problem Ceiling Light in the UK Electrical Forum area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
