A
axel132132
Hi
I have an issue at a bungalow im working at, there is a fault
All the sockets are on a ring, when i plug something in the living room it trips the RCD plug it into any other sockets it dosent trip the RCD
The board is MAIN SWITCH RCD
Cheers
used to be a good code 3 on the old PIRs..... further investigation required.
Yeh will change socket and megger old socket at back to check if its shorted anywere thanks for help hopefully its socket and will save me some time :24:
axel,
It matters a great deal if you are carrying out fraudulent business practices.
However if you can produce a valid reg number then I stand corrected and will apologise.
Problem on job with bungalow
axel132132,
sbrown2,
