Problem with computers and electricity, need help! | Page 2 | on ElectriciansForums
Discuss Problem with computers and electricity, need help! in the UK Electrical Forum area at ElectriciansForums.net
spikesot
Hi, I wanted to comment a problem that has caused me problems over 2 years.
The problem is that I have 3 different computers, and tried one by one, and when are connected to electricity the computer slow down for a random period of time (the slow downs or delay comes better at mornings, at nights computer normally works better) causing my mouse and keyboard delay and slow-down too, really annoying.
I tried 3 different computers and same problem on them, it happens too with Play Station 3 and XBOX 360. I studied computing and i know that this problem is not related to the computers, the only thing that can be is an electricity problem on my house, but donยดt know how to solve that... maybe harmonics?.
If anyone has any solution please I would be very grateful, thank you very much.
Okey, the thing is that i tried formatting 3 or 4 times with each computer and same problem, and its not a problem related with computer cause on ps3 or xbox im having the same problem.
Info which would have been better placed in your opening post, instead of sending us on a wild goose chase ... when you say your PS3 and XBOX are they been played online?... its all starting to sound like a slow network connection, you power supply is filtered by these computers etc to soften small variations ... larger ones will either blow your power packs or the computers will power off with low voltage.
If you see the opening post you will see that i wrote that. Yes, my PS3 and XBOX are connected to the Internet, but this makes no sense, its not "lag" or high ping (because the ping is ok), is about mouse, keyboard and dualshock delay when moving or shooting on any game or simillar.
Its not mains related, end of story. The SMP's in your machines are designed to work across a broad spectrum of voltage and frequency and the internal clocking speeds on the motherboards are governed by electronics far smarter than you.
Why its not mains related? i mean, its not computer problem cause i tried with 3 different ones, and it happens too on PS3 and XBOX360, and i changed my broadband company to other different since 3 months, still happening the same problem.
The circuitry works at 5 & 12V DC
Your broadband company is a service provider but you still use the same line for your internet ... thats why we are saying check your actual broadband speed ... changing service provider just means you pay someone else ...they don't run new cables to your house with faster speeds unless you have been told they are independent with a new cable network.
Your response to my post last is all symptoms of slow broadband speed, really getting tired of trying to tell you this, your electricity supply cannot give these symptoms you express, I bet you are miles away from the exchange for your telephone line hence you are in a queue of anyone nearer the exchange. This may effect mouse keyboard etc because your computer is still trying to process a slow connection while you give it another command.
It like going to the bar for several drinks and waiting in the queue ... then your mate says get me some nuts too... he won't get his nuts until your turn at the bar, in reflection your computer is doing the same its processing a internet link and your adding extra onto it and expecting instant response.
Turn your internet connection of and play some pre-installed games or something and see if the lag exists while you are offline, if its only present when connected to the internet then you have most likely got a crap broadband speed, I'm avoiding the many other possibilities as you say it also effects your consoles too and if you in an online game on a slow broadband speed it will delay your reactions until its made contact and replied to your last reactions..hence you get lag effect.
Check your providers claims on broadband speed I bet it says UP TO Mbytes meaning anything from no signal to their unrealistic claims.
Because the power supplies in your computers etc will take a very broad voltage input (usually something like 90 to 250 volts) and convert to 12, 5 and 3 volts.
Whatever your electricity supply does the power supply will either maintain those voltages, turn off or explode.
Not the same specific line of Internet, now i have 50 Mbs with optical fiber and before i had adsl cables.
You are getting good advice from the previous posts. A drop in the mains voltage will not slow your computer down. Switch-mode power supplies will allow a heck of a drop in supply and still maintain their regulated DC output rails, which has been already stated are 3.3V, 5V, 12V and probably even a sub 3.3V one these days. Daz
A question no one has asked is you say they are slow using a mouse or keyboard or controller, are these wireless? Or hard wired? Also you say you have tried different computers but have you tried different mice and keyboard?
Of course man, i tried with 2 different keyboards and 3 mouses, and same problem, and theyยดre all wired. Tried with different Monitor too.
Btw thanks for all the advice you guys are giving to me, thanks a lot.
most of the time it is because of overloaded hard drive. But you said that you tried to format it. Are you downloading torrents. Because it happens with my laptop when i some downloading is in process specially torrents. Or may be you have installed some heavy type of software.
Reply to Problem with computers and electricity, need help! in the UK Electrical Forum area at ElectriciansForums.net
As a trainee, one of the things I've tried to focus on to deepen my interest in the world of electrics, is the space for creativity. I've...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
